Trying to get a bunch of odds and ends done on my wagon while I have time before Moab.
Last weekend I pulled the driver's door window out to lube and adjust. It was so hard to roll up that it took two hands, one to wind the crank, and the other to pull up on the glass.
I loosened the interior window trim screws a tad to take some of the pressure off of the window channel which was pretty tight. I also pulled out the regulator and scissor arms and cleaned and lubed them.
Put it all back together, and it works much better. It's still a little stiff, but the glass will go up and down without much effort.
I also fixed my horn. The previous owner had installed a cheap plastic horn, and wired it to a steering column mounted tin button. It looked ugly, and sounded like a dying calf in a rain storm when "honked". Since it didn't work worth a damn, I removed the cheap button and stuffed it under the dash years ago and haven't had a working horn since.
Joseph saved the horns from the Cadillac crash car from last summer, so I had a pair of good horns laying around. I mounted them next to the radiator in a couple of existing holes. They look like they are supposed to be there.
I also replaced the wire in the steering column which had been spliced before and was just hanging out of the bottom of the column tube. The wire is crimped to a brass contact under the horn button, so I cut the wire off flush, drilled out the remains of wire, and soldered a new wire into the contact.
The old horn was wired through a horn relay, but I found that the reason the old horn didn't work right was that it was wired ass-backwards and the relay wasn't doing anything at all. I swear, nearly everything that the previous owner had done to the wagon was upside down, backwards, or just stupidly wrong.
The old relay was still good, so I wired it correctly to the horn button, and it works great. It's nice to have a working horn after all these years. I've had a few near misses on the road and a good horn would have helped...
The old cheapo horn-
The new GM horns-
Once I had the horn wrapped up, I decided to take a look at the rear shackle bushings. I could tell the bushings were worn from the cracked edges and sag, but here's what I found when I got them out.
These bushings are about 5 years old... The rubber parts available from Crown and Omix-ADA leaves alot to be desired to say the least. These bushings are in worse shape after five years than the original Willys bushings they replaced that were 60 years old.
The stuff they sell may be fine for trailer queens or museum cars, but I drive my wagon daily and want it to last. I didn't want to bother with buying more crap rubber bushings that would begin to fail upon installation, so I ordered a CJ shackle kit online with poly bushings hoping they would fit. When I got the kit, I found that the bushings were a bit small, but the kit came with slightly longer shackles and grease bolts. The 1/2"-3/4" lift I'll get with these shackles won't hurt...
I was able to find a set of poly bushings that I think will work, with the grease bolts and sleeves of the CJ shackle kit. As soon as the parts arrive, I'll see if it will all go together...
More to come!
